It is currently Tue Jul 15, 2025 11:16 pm
 Post subject: LP TV Special
PostPosted: Sun Apr 13, 2014 6:06 pm
First name: D
Last Name: S
Working on a LP flat top. Similat to a LP TV Special for my daughter.
She is doing great on her acoustic, finger picking and strumming.
I want to minimize stuff on the top.
All gold hardware. Mini neck humbucker, one piece intonated bridge, one volume.
I plan to mimic Gibson's ocean perimeter blue and green color scheme.
A. Mahog neck, Sapele body, Maple top, and Mesquite fretboard.
I plan to make an Ebony truss cover with her initial inlayed.
I may make an Ebony finger rest as well.
This will be a set neck with a simple neck pocket.
Comments and suggestions welcome.
Dan
wah
Wah-wah-wah-wah
Wah
 Post subject: Re: LP TV Special
PostPosted: Sun Apr 13, 2014 6:54 pm
You say LP TV - which was a specific finish.... so will you do that on a maple top? Or just the hog?
PostPosted: Sun Apr 13, 2014 8:16 pm
First name: D
Last Name: S
Nope, no yelllow. Maybe this is a Special? Or a Melody Maker with traditional head?
wah
Wah-wah-wah-wah
Wah
PostPosted: Thu May 01, 2014 12:32 pm
First name: D
Last Name: S
Progress pics.
wah
Wah-wah-wah-wah
Wah
PostPosted: Thu Jul 03, 2014 5:40 pm
First name: D
Last Name: S
Started applying the lacquer.
I'll be back in two months. Argh!
wah
Wah-wah-wah-wah
Wah
PostPosted: Thu Jul 03, 2014 6:52 pm
Man! That thing POPS!
PostPosted: Thu Jul 03, 2014 7:10 pm
First name: D
Last Name: S
Thanks, Chris!
I applied dye directly to the wood. I put on a water conditioner,
applied a dark blue dye, sanded most of it off, and then applied green and blue.
I then buffed it with steel wool to lighten it up in the middle and blend it.
I like the dye on bare wood.
My book match does not match well, because I fed it through a planer.
The planer took out chunks, so the top as shown is the two outside surfaces of my board.
Lesson learned.
Dan
wah
Wah-wah-wah-wah
Wah
PostPosted: Wed Jul 09, 2014 3:16 pm
First name: Matthew
Last Name: Lucas
City: Saugerties
State: New York
Zip/Postal Code: 12477
I think you should go with a p90 pickup. Not because its an LP Jr style.......Ok yeah because it's an LP Jr style. Haha just my opinion. It's a very nice body
These users thanked the author mlucas123 for the post: dzsmith (Thu Jul 10, 2014 7:59 pm)
PostPosted: Thu Jul 10, 2014 9:40 am
First name: Patrick
Last Name: Hanna
State: Missouri
That is a really cool guitar. I like the simplicity of the electronics and I think the color is excellent.
PostPosted: Thu Jul 10, 2014 10:05 am
First name: D
Last Name: S
Thanks, Patrick!
I want to keep the top open for my daughter's finger picking. The back of the neck is flat to encourage her to place her thumb on the back.
I hope the fixed bridge does not guve me intonation problems.
Dan
wah
Wah-wah-wah-wah
Wah
PostPosted: Tue Jul 29, 2014 11:02 am
First name: Freeman
Last Name: Keller
Dan, that is quite stunning. Your daughter should be very happy (and lucky). Your timing is good - I have a piece of wood that I want to make into a flat top and have been considering an LP Jr but have a few questions. I've built a carved top LP, but don't have plans for a Jr and was wondering about the neck pocket and general geometry. It looks like you've angled the neck four degrees or so and built a shim for the fretboard extension. Can you comment on setting this angle?
I've been considering chambering the body to bring the weight down a little - thoughts? Also thinking about various pickup options - one or two P90's or something similar or possible one neck pickup and that ToM bridge that Braggs makes with the piezo's in it.
PostPosted: Tue Jul 29, 2014 11:30 am
+1000!
And I vote for a P90 too. Just love that sound. Using one is the main reason I want to build a solid body electric!
PostPosted: Tue Jul 29, 2014 5:51 pm
First name: D
Last Name: S
Thanks, Nick!
Well, I knew the blue dye would fade hanging in my garage for two months.
Disapointed that I did not keep it in the dark.
I reckon my daughter will be Ok with it.
I'm polishing it tonight.
I'll see how the mini bucker sounds. The cavity may be the right size for a P90.
I'm getting nervous about the fixed bridge. I did not want to install the bushings before I applied the finish. I measured three times which is two more than normal.
Dan
wah
Wah-wah-wah-wah
Wah
PostPosted: Tue Jul 29, 2014 6:11 pm
First name: D
Last Name: S
Thanks Freeman!
I made templates for the end of the neck and neck pocket. The end of the neck is straight, so the fretboard hangs over the sides of the neck. I put shims under the pocket template and cut out the pocket at an angle. Nothing special, I did not go with the normal tenon. More like a tilted Fender pocket.
To set the neck angle, I did a mockup of the bridge and fretboard on the body and measured the angle. Not sure what is was, I think about 3-4 degrees. The body is some type of African Mahogany. I drilled out large holes to relieve some of the weight.
wah
Wah-wah-wah-wah
Wah
PostPosted: Wed Jul 30, 2014 1:46 pm
Last Name: Sollod
Very Nice Dan! What wood is the fingerboard? It looks like you book-matched it...
www.swiftcreekguitars.com
PostPosted: Wed Jul 30, 2014 5:55 pm
First name: D
Last Name: S
thanks Steve!
The fretboard is home harvested Mesquite. I just love the stuff.
wah
Wah-wah-wah-wah
Wah
PostPosted: Wed Jul 30, 2014 11:52 pm
Dan, it's looking nice. From the picture I can't tell if the top is arched or flat like a LP Junior? The finish looks really nice!
PostPosted: Thu Jul 31, 2014 12:07 pm
First name: D
Last Name: S
Thanks, Anthony!
Flat top.
wah
Wah-wah-wah-wah
Wah
PostPosted: Sun Aug 10, 2014 2:43 pm
First name: Stuart
Last Name: Gort
Ooh...that's going to look FINE with some shiny on it! Nice.
StuMusic
These users thanked the author Stuart Gort for the post: dzsmith (Sun Aug 10, 2014 3:15 pm)
PostPosted: Fri Sep 05, 2014 8:43 pm
First name: D
Last Name: S
Finished it.
The intonation of the fixed bridge is excellent.
I located the bridge by using the scale length + 0.1" from nut to the low E saddle and it was right on.
My daughter is quite happy, which is all that really matters.
The pickup has a nice mellow sound.
I put some Fender stainless steel light gauge strings on it, but i think she would prefer Nickel strings.
Dan
wah
Wah-wah-wah-wah
Wah
PostPosted: Fri Sep 05, 2014 8:58 pm
First name: Jamie
Last Name: Unden
City: Lakeside
Zip/Postal Code: 92040
Very nice! I could shave in that... if I shaved...
PostPosted: Fri Sep 05, 2014 8:59 pm
First name: D
Last Name: S
Ha! Thanks Jamie!
Dan
wah
Wah-wah-wah-wah
Wah
PostPosted: Fri Sep 05, 2014 11:07 pm
Classy!
These users thanked the author Chris Pile for the post: dzsmith (Sat Sep 06, 2014 9:33 am)
PostPosted: Sat Sep 06, 2014 8:01 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
nice!
Brian
These users thanked the author B. Howard for the post: dzsmith (Sat Sep 06, 2014 9:33 am)
PostPosted: Mon Sep 08, 2014 4:53 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
I really have to start checking out this forum more often! That's a sweet guitar you made for your daughter. She looks very pleased! Once again, you've put your harvest of mesquite to fine use, Dan.
If I ever try my hand at an electric, thats the model that I would like to try. Very nice work! :D
Alex
Users browsing this forum: Bing [Bot] and 1 guest
